REST API reference
Delete a FlexCache volume
Deletes a FlexCache volume, removing it from your storage system. This operation is useful when you no longer need the FlexCache and want to reclaim the resources it consumes.
HTTP method and endpoint
DELETE /storage/flexcache/flexcaches/{uuid}
Introduced in
ONTAP 9.6
Usage notes
If a FlexCache volume is online, it is offlined before deletion.
  • volume flexcache delete
uuid
string
path
True
Unique identifier of the FlexCache.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
66846879
The specified volume UUID is not a FlexCache volume
66846731
Failed to delete the FlexCache volume
524546
Failed to delete the FlexCache volume because the FlexCache volume is not unmounted
66846980
Failed to delete the FlexCache volume because it has the writeback property enabled
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
