Removes the ems role-based configuration of the access control role
DELETE /support/ems/role-configs/{access_control_role.name}
Introduced In: 9.13
Removes the EMS role-based configuration of the access control role.
Related ONTAP commands
event role-config delete
access_control_role.name |
string |
path |
True |
Access control role name |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
