REST API reference
Remove the EMS role-based configuration for an access control role
Removes the EMS role-based configuration from an access control role to update or clean up your role settings.
HTTP method and endpoint
DELETE /support/ems/role-configs/{access_control_role.name}
Introduced in
ONTAP 9.13
Usage notes
Removes the EMS role-based configuration of the access control role.
  • event role-config delete
string
path
True
Access control role name
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
