REST API reference
Display MetroCluster diagnostics
Initiate and retrieve the results of MetroCluster diagnostics operations for configurations over IP. Use these endpoints to assess the health of various components such as nodes, aggregates, and clusters, with the option to view detailed check results.
Overview
You can use this API to initiate a MetroCluster diagnostics operation and fetch the results of a completed diagnostics operation on a MetroCluster over IP configuration. The GET operation retrieves the results of a completed diagnostics operation for the MetroCluster over IP configuration. These can include the overall high level and details for the checks done for different components. By default, the response does not include the details. If the fields query is used in the request, the response will include the details. The POST request can be used to start a MetroCluster diagnostics operation or set up a schedule for the diagnostics to be run periodically.
Details
Details provide a way to view all the checks done on a component and the result of each check. The details of the checks are not included in the response by default. In order to fetch the details, use the fields query parameter.
  • node.details
  • aggregate.details
  • cluster.details
Starting a MetroCluster diagnostics operation
A new MetroCluster diagnostics operation can be started by issuing a POST to /cluster/metrocluster/diagnostics. There are no extra parameters required to initiate a diagnostics operation.
Polling the POST job for status of diagnostics operation
After a successful POST /cluster/diagnostics operation is issued, an HTTP status code of 202 (Accepted) is returned along with a job UUID and a link in the body of the response. The POST job continues asynchronously and can be monitored by using the job UUID and the /cluster/jobs API. The "message" field in the response of the GET /cluster/jobs/{uuid} request shows the current step in the job, and the "state" field shows the overall state of the job.
Running the diagnostics operation
This example shows the POST request for starting a diagnostic operation for a MetroCluster over IP configuration and the responses returned:
#API
/api/cluster/metrocluster/diagnostics
POST Request
curl -X POST https://<mgmt-ip>/api/cluster/metrocluster/diagnostics
POST Response
HTTP/1.1 202 Accepted
Date: Tue, 22 Sep 2020 17:20:53 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
"job": {
  "uuid": "f7d3804c-fcf7-11ea-acaf-005056bb47c1",
      "href": "/api/cluster/jobs/f7d3804c-fcf7-11ea-acaf-005056bb47c1"
Monitoring the job progress
Use the link provided in the response to the POST request to fetch information for the diagnostics operation job.
Request
curl -X GET https://<mgmt-ip>/api/cluster/jobs/f7d3804c-fcf7-11ea-acaf-005056bb47c1
Job status response
Date: Tue, 22 Sep 2020 17:21:12 GMT
Content-Length: 345
"description": "POST /api/cluster/metrocluster/diagnostics",
"state": "running",
"message": "Checking nodes...",
"code": 2432853,
"start_time": "2020-09-22T13:20:53-04:00",
Final status of the diagnostics job
Date: Tue, 22 Sep 2020 17:29:04 GMT
Content-Length: 372
"state": "success",
"message": "success",
"code": 0,
"end_time": "2020-09-22T13:22:04-04:00",
Retrieving the diagnostics operation
Request
curl -X GET https://<mgmt-ip>/api/cluster/metrocluster/diagnostics
Date: Tue, 22 Sep 2020 18:04:28 GMT
Content-Length: 1005
"node": {
  "timestamp": "2020-09-22T13:47:01-04:00",
  "state": "ok",
  "summary": {
    "message": ""
"interface": {
  "state": "ok",
  "summary": {
    "message": ""
"aggregate": {
  "state": "ok",
  "summary": {
    "message": ""
"cluster": {
  "state": "ok",
  "summary": {
    "message": ""
"connection": {
  "state": "ok",
  "summary": {
    "message": ""
"volume": {
  "state": "ok",
  "summary": {
    "message": ""
"config_replication": {
  "state": "ok",
  "summary": {
    "message": ""
    "href": "/api/cluster/metrocluster/diagnostics"
Retrieving check details for the node component
Request
curl -X GET https://<mgmt-ip>/api/cluster/metrocluster/diagnostics?fields=node.details
HTTP/1.1 200 OK
Date: Thu, 10 Feb 2022 00:05:12 GMT
Content-Length: 4506
"node": {
  "details": [
      "node": {
        "uuid": "11111111-1111-1111-1111-111111111111",
        "name": "node1",
            "href": "/api/cluster/nodes/11111111-1111-1111-1111-111111111111"
      "cluster": {
        "uuid": "12121212-1212-1212-1212-121212121212",
        "name": "clusterA",
            "href": "/api/cluster/12121212-1212-1212-1212-121212121212"
      "timestamp": "2022-02-09T18:47:00-05:00",
      "checks": [
          "name": "node_reachable",
          "result": "ok"
          "name": "metrocluster_ready",
          "result": "ok"
          "name": "local_ha_partner",
          "result": "ok"
          "name": "ha_mirroring_on",
          "result": "ok"
          "name": "ha_mirroring_op_state",
          "result": "ok"
          "name": "symmetric_ha_relationship",
          "result": "ok"
          "name": "remote_dr_partner",
          "result": "ok"
          "name": "dr_mirroring_on",
          "result": "ok"
          "name": "dr_mirroring_op_state",
          "result": "ok"
          "name": "symmetric_dr_relationship",
          "result": "ok"
          "name": "remote_dr_auxiliary_partner",
          "result": "ok"
          "name": "symmetric_dr_auxiliary_relationship",
          "result": "ok"
          "name": "storage_failover_enabled",
          "result": "ok"
          "name": "has_intercluster_lif",
          "result": "ok"
          "name": "node_object_limit",
          "result": "ok"
          "name": "automatic_uso",
          "result": "ok"
      "node": {
        "uuid": "22222222-2222-2222-2222-222222222222",
        "name": "node2",
            "href": "/api/cluster/nodes/22222222-2222-2222-2222-222222222222"
      "cluster": {
        "uuid": "23232323-2323-2323-2323-232323232323",
        "name": "clusterB",
            "href": "/api/cluster/23232323-2323-2323-2323-232323232323"
      "checks": [
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
          "result": "ok"
Retrieving check details for the volume component
Request
curl -X GET https://<mgmt-ip>/api/cluster/metrocluster/diagnostics?fields=volume.details
HTTP/1.1 200 OK
Connection: close
Date: Fri, 08 Apr 2022 20:07:38 GMT
Vary: Accept-Encoding
Content-Length: 928
Client-Date: Fri, 08 Apr 2022 20:07:42 GMT
Client-Peer: 172.21.138.189:443
Client-Response-Num: 1
Client-SSL-Cert-Issuer: /CN=sti75-vsim-ucs180f0e_siteA/C=US
Client-SSL-Cert-Subject: /CN=sti75-vsim-ucs180f0e_siteA/C=US
Client-SSL-Cipher: ECDHE-RSA-AES256-GCM-SHA384
Client-SSL-Socket-Class: IO::Socket::SSL
Client-SSL-Warning: Peer certificate not verified
Content-Security-Policy: default-src 'self'; script-src 'self' 'unsafe-inline'; style-src 'self' 'unsafe-inline'; img-src 'self' data:; frame-ancestors: 'self'
"volume": {
  "details": [
      "checks": [
          "name": "unmirrored_flexgroups",
          "result": "ok",
      "checks": [
          "name": "mixed_flexgroups",
          "result": "ok",
  • metrocluster check run
  • metrocluster check show
  • metrocluster check node show
  • metrocluster check aggregate show
  • metrocluster check cluster show
