REST API reference
Display MetroCluster diagnostics
Initiate and monitor MetroCluster diagnostics operations for IP configurations using these endpoints. Start diagnostics operations, set schedules, and retrieve results to assess the health and functionality of your MetroCluster setup.
Overview
You can use this API to initiate a MetroCluster diagnostics operation and fetch the results of a completed diagnostics operation on a MetroCluster over IP configuration. The GET operation retrieves the results of a completed diagnostics operation for the MetroCluster over IP configuration. The POST request can be used to start a MetroCluster diagnostics operation or set up a schedule for the diagnostics to be run periodically.
Starting a MetroCluster diagnostics operation
A new MetroCluster diagnostics operation can be started by issuing a POST to /cluster/metrocluster/diagnostics. There are no extra parameters required to initiate a diagnostics operation.
Polling the POST job for status of diagnostics operation
After a successful POST /cluster/diagnostics operation is issued, an HTTP status code of 202 (Accepted) is returned along with a job UUID and a link in the body of the response. The POST job continues asynchronously and can be monitored by using the job UUID and the /cluster/jobs API. The "message" field in the response of the GET /cluster/jobs/{uuid} request shows the current step in the job, and the "state" field shows the overall state of the job.
Running the diagnostics operation
This example shows the POST request for starting a diagnostic operation for a MetroCluster over IP configuration and the responses returned:
#API
/api/cluster/metrocluster/diagnostics
POST Request
curl -X POST https://<mgmt-ip>/api/cluster/metrocluster/diagnostics
POST Response
HTTP/1.1 202 Accepted
Date: Tue, 22 Sep 2020 17:20:53 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
"job": {
  "uuid": "f7d3804c-fcf7-11ea-acaf-005056bb47c1",
      "href": "/api/cluster/jobs/f7d3804c-fcf7-11ea-acaf-005056bb47c1"
Monitoring the job progress
Use the link provided in the response to the POST request to fetch information for the diagnostics operation job.
Request
curl -X GET https://<mgmt-ip>/api/cluster/jobs/f7d3804c-fcf7-11ea-acaf-005056bb47c1
Job status response
Date: Tue, 22 Sep 2020 17:21:12 GMT
Content-Length: 345
"description": "POST /api/cluster/metrocluster/diagnostics",
"state": "running",
"message": "Checking nodes...",
"code": 2432853,
"start_time": "2020-09-22T13:20:53-04:00",
Final status of the diagnostics job
Date: Tue, 22 Sep 2020 17:29:04 GMT
Content-Length: 372
"state": "success",
"message": "success",
"code": 0,
"end_time": "2020-09-22T13:22:04-04:00",
Retrieving the diagnostics operation
Request
curl -X GET https://<mgmt-ip>/api/cluster/metrocluster/diagnostics
Date: Tue, 22 Sep 2020 18:04:28 GMT
Content-Length: 1005
"node": {
  "timestamp": "2020-09-22T13:47:01-04:00",
  "state": "ok",
  "summary": {
    "message": ""
"interface": {
  "state": "ok",
  "summary": {
    "message": ""
"aggregate": {
  "state": "ok",
  "summary": {
    "message": ""
"cluster": {
  "state": "ok",
  "summary": {
    "message": ""
"connection": {
  "state": "ok",
  "summary": {
    "message": ""
"volume": {
  "state": "ok",
  "summary": {
    "message": ""
"config_replication": {
  "state": "ok",
  "summary": {
    "message": ""
    "href": "/api/cluster/metrocluster/diagnostics"
  • metrocluster check run
  • metrocluster check show
