Retrieves a specific chassis
system chassis fru show# learn more -
doc /cluster/chassis](#docs-cluster-cluster_chassis)
GET /cluster/chassis/{id}
Introduced In: 9.6
Retrieves a specific chassis.
Related ONTAP commands
system chassis show -
Learn more
id |
string |
path |
True |
Chassis ID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
frus |
array[frus] |
List of FRUs in the chassis. |
id |
string |
nodes |
array[nodes] |
List of nodes in the chassis. |
shelves |
array[shelf_reference] |
List of shelves in chassis. |
state |
string |
"frus": [
"id": "string",
"state": "string",
"type": "string"
"id": "021352005981",
"nodes": [
"href": "/api/resourcelink"
"name": "node1",
"pcis": {
"cards": [
"device": "Intel Lewisburg series chipset SATA Controller",
"info": "Additional Info: 0 (0xaaf00000) SHM2S86Q120GLM22NP FW1146 114473MB 512B/sect (SPG190108GW)",
"slot": "0"
"position": "top",
"usbs": {
"ports": [
"shelves": [
"uid": "7777841915827391056"
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
frus
id |
string |
state |
string |
type |
string |
href |
string |
_links
self |
cards
device |
string |
The description of the PCI card. |
info |
string |
The info string from the device driver of the PCI card. |
slot |
string |
The slot where the PCI card is placed. This can sometimes take the form of "6-1" to indicate slot and subslot. |
pcis
cards |
array[cards] |
ports
connected |
boolean |
Indicates whether or not the USB port has a device connected to it. |
usbs
The status of the USB ports on the controller.
enabled |
boolean |
Indicates whether or not the USB ports are enabled. |
ports |
array[ports] |
supported |
boolean |
Indicates whether or not USB ports are supported on the current platform. |
nodes
List of nodes in chassis.
_links |
name |
string |
pcis |
position |
string |
The position of the node in the chassis, when viewed from the rear of the system. |
usbs |
The status of the USB ports on the controller. |
uuid |
string |
shelf_reference
Shelf
_links |
uid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
