REST API reference
Retrieve counter rows
Accesses counter rows to review a collection of performance data metrics. This is helpful when you need to analyze system performance and diagnose potential issues.
HTTP method and endpoint
GET /cluster/counter/tables/{counter_table.name}/rows
Introduced in
ONTAP 9.11
Usage notes
Returns a collection of counter rows.
counter_table.name
string
path
True
Counter table name.
counters.value
integer
query
False
Filter by counters.value
counters.name
string
query
False
Filter by counters.name
counters.counters.label
string
query
False
Filter by counters.counters.label
counters.counters.values
integer
query
False
Filter by counters.counters.values
counters.values
integer
query
False
Filter by counters.values
counters.labels
string
query
False
Filter by counters.labels
id
string
query
False
Filter by id
properties.name
string
query
False
Filter by properties.name
properties.value
string
query
False
Filter by properties.value
aggregation.complete
boolean
query
False
Filter by aggregation.complete
aggregation.count
integer
query
False
Filter by aggregation.count
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[counter_row]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "counter_table": {
        "name": "string"
      "counters": [
          "counters": [
              "label": "string",
              "values": [
                "integer"
          "labels": [
            "string"
          "name": "string",
          "values": [
            "integer"
      "id": "string",
      "properties": [
          "name": "string",
          "value": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
8585320
Table requested is not found
8586228
Invalid counter name request.
8586229
Invalid counter property request.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
instance_counter_aggregation
Aggregation information about this counter.
complete
boolean
The aggregation state for this row. For non-aggregated tables: Not present For aggregated tables: If all requests to remote nodes for counter data are successful, then this value will be 'true'. If any requests to remote nodes fail, then this value will be 'false'.
count
integer
Number of nodes included in the aggregation of this counter.
counter_table_reference
Counter table reference.
_links
_links
name
string
Counter table name.
counter2d
Counters that represent the second dimension of a two-dimension counter.
label
string
Second dimension label.
values
array[integer]
List of values for the counter.
counter
Representation of a counter and contains one of the following:
  • Scalar counter populates the 'name' and 'value' fields.
  • A 1D array populates the 'name', 'labels' and 'values' fields.
  • A 2D array is represented as a list of counter entries.
"counters": [
  // Scalar counter
      "name": "memory",
      "value": 4480
  // one dimensional array "sys_read_latency_hist"
      "name": "sys_read_latency_hist",
      "labels": ["0 - <1ms", "1 - <2ms", ...],
      "values": [0, 0, ...]
  // Two dimensional array "foo" with ["Label 1", "Label 2"] as the first
  // array dimension and labels ["w", "x", "y"] for the 2nd dimension
      "name": "foo",
      "labels": ["Label 1", "Label 2"],
      "counters": [
              "label": "x",
              "values": [0, 0]
              "label": "y",
              "values": [0, 0]
              "label": "z",
              "values": [0, 0]
counters
array[counter2d]
List of labels and values for the second dimension.
labels
array[string]
List of labels for the first dimension.
name
string
Counter name.
value
integer
Scalar value.
values
array[integer]
List of values in a one-dimensional counter.
counter_property
Single string counter entry.
name
string
Property name.
value
string
Property value.
counter_row
A single row of counter and property counter data.
_links
_links
aggregation
counter_table
counters
array[counter]
Array of counter name/value pairs.
id
string
Unique row idenfier.
properties
array[counter_property]
Array of property name/value pairs.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
