Retrieve counter rows
Accesses and reviews a collection of counter rows, which are essential for monitoring and analyzing performance metrics.
HTTP method and endpoint
GET /cluster/counter/tables/{counter_table.name}/rows
Introduced in
ONTAP 9.11
Usage notes
Returns a collection of counter rows.
counter_table.name |
string |
path |
True |
Counter table name. |
aggregation.complete |
boolean |
query |
False |
Filter by aggregation.complete |
aggregation.count |
integer |
query |
False |
Filter by aggregation.count |
counters.labels |
string |
query |
False |
Filter by counters.labels |
counters.value |
integer |
query |
False |
Filter by counters.value |
counters.counters.values |
integer |
query |
False |
Filter by counters.counters.values |
counters.counters.label |
string |
query |
False |
Filter by counters.counters.label |
counters.values |
integer |
query |
False |
Filter by counters.values |
counters.name |
string |
query |
False |
Filter by counters.name |
properties.name |
string |
query |
False |
Filter by properties.name |
properties.value |
string |
query |
False |
Filter by properties.value |
id |
string |
query |
False |
Filter by id |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[counter_row] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"counter_table": {
"name": "string"
"counters": [
"counters": [
"label": "string",
"values": [
"integer"
"labels": [
"string"
"name": "string",
"values": [
"integer"
"id": "string",
"properties": [
"name": "string",
"value": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8585320 |
Table requested is not found |
8586228 |
Invalid counter name request. |
8586229 |
Invalid counter property request. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
instance_counter_aggregation
Aggregation information about this counter.
complete |
boolean |
The aggregation state for this row. For non-aggregated tables: Not present For aggregated tables: If all requests to remote nodes for counter data are successful, then this value will be 'true'. If any requests to remote nodes fail, then this value will be 'false'. |
count |
integer |
Number of nodes included in the aggregation of this counter. |
counter_table_reference
Counter table reference.
_links |
name |
string |
counter2d
Counters that represent the second dimension of a two-dimension counter.
label |
string |
Second dimension label. |
values |
array[integer] |
List of values for the counter. |
counter
Representation of a counter and contains one of the following:
Scalar counter populates the 'name' and 'value' fields.
A 1D array populates the 'name', 'labels' and 'values' fields.
A 2D array is represented as a list of counter entries.
"counters": [
// Scalar counter
"name": "memory",
"value": 4480
// one dimensional array "sys_read_latency_hist"
"name": "sys_read_latency_hist",
"labels": ["0 - <1ms", "1 - <2ms", ...],
"values": [0, 0, ...]
// Two dimensional array "foo" with ["Label 1", "Label 2"] as the first
// array dimension and labels ["w", "x", "y"] for the 2nd dimension
"name": "foo",
"labels": ["Label 1", "Label 2"],
"counters": [
"label": "x",
"values": [0, 0]
"label": "y",
"values": [0, 0]
"label": "z",
"values": [0, 0]
counters |
array[counter2d] |
List of labels and values for the second dimension. |
labels |
array[string] |
List of labels for the first dimension. |
name |
string |
Counter name. |
value |
integer |
Scalar value. |
values |
array[integer] |
List of values in a one-dimensional counter. |
counter_property
Single string counter entry.
name |
string |
Property name. |
value |
string |
Property value. |
counter_row
A single row of counter and property counter data.
_links |
aggregation |
Aggregation information about this counter. |
counter_table |
Counter table reference. |
counters |
array[counter] |
Array of counter name/value pairs. |
id |
string |
Unique row idenfier. |
properties |
array[counter_property] |
Array of property name/value pairs. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
