Retrieve counter tables with schema definitions
Accesses a collection of counter tables and their schema definitions to review or analyze performance data within your ONTAP environment.
HTTP method and endpoint
GET /cluster/counter/tables
Introduced in
ONTAP 9.11
Usage notes
Returns a collection of counter tables and their schema definitions.
counter_schemas.name |
string |
query |
False |
Filter by counter_schemas.name |
counter_schemas.denominator.name |
string |
query |
False |
Filter by counter_schemas.denominator.name |
counter_schemas.unit |
string |
query |
False |
Filter by counter_schemas.unit |
counter_schemas.type |
string |
query |
False |
Filter by counter_schemas.type |
counter_schemas.description |
string |
query |
False |
Filter by counter_schemas.description |
name |
string |
query |
False |
Filter by name |
description |
string |
query |
False |
Filter by description |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[counter_table] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"counter_schemas": [
"denominator": {
"name": "string"
"description": "string",
"name": "string",
"type": "string",
"unit": "string"
"name": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8585368 |
The system has not completed it's initialization |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
counter_denominator
Counter used as the denominator in calculating the resulting value of averages and percentages.
name |
string |
Counter name. |
counter_schema
Schema definition of a single counter or property.
denominator |
Counter used as the denominator in calculating the resulting value of averages and percentages. |
description |
string |
Counter or property description. |
name |
string |
Counter or property name. |
type |
string |
Type of counter or property. Properties will always set this field to 'string'. |
unit |
string |
Counter unit. |
counter_table
Information for a single counter table.
_links |
counter_schemas |
array[counter_schema] |
Array of counter schema definitions. |
description |
string |
Description of the table. |
name |
string |
Table name. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
