REST API reference
Retrieve counter tables with schema definitions
GET /cluster/counter/tables
Introduced In: 9.11
Returns a collection of counter tables and their schema definitions.
name
string
query
False
Filter by name
counter_schemas.unit
string
query
False
Filter by counter_schemas.unit
counter_schemas.type
string
query
False
Filter by counter_schemas.type
counter_schemas.denominator.name
string
query
False
Filter by counter_schemas.denominator.name
counter_schemas.name
string
query
False
Filter by counter_schemas.name
counter_schemas.description
string
query
False
Filter by counter_schemas.description
description
string
query
False
Filter by description
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[counter_table]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "counter_schemas": [
          "denominator": {
            "name": "string"
          "description": "string",
          "name": "string",
          "type": "string",
          "unit": "string"
      "name": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
8585368
The system has not completed it's initialization
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
counter_denominator
Counter used as the denominator in calculating the resulting value of averages and percentages.
name
string
Counter name.
counter_schema
Schema definition of a single counter or property.
denominator
counter_denominator
description
string
Counter or property description.
name
string
Counter or property name.
type
string
Type of counter or property. Properties will always set this field to 'string'.
unit
string
Counter unit.
counter_table
Information for a single counter table.
_links
_links
counter_schemas
array[counter_schema]
Array of counter schema definitions.
description
string
Description of the table.
name
string
Table name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
