REST API reference
Retrieve details of an asynchronous job
Accesses the details of a specific asynchronous job, which can be useful for monitoring job progress and outcomes before it is automatically deleted.
HTTP method and endpoint
GET /cluster/jobs/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the details of a specific asynchronous job. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
uuid
string
path
True
Job UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
code
integer
If the state indicates "failure", this is the final error code.
description
string
The description of the job to help identify it independent of the UUID.
end_time
string
The time the job ended.
error
error
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed.
message
string
A message corresponding to the state of the job providing additional details about the current state.
node
node
The node where this job was run
start_time
string
The time the job started.
state
string
The state of the job.
svm
svm
uuid
string
      "href": "/api/resourcelink"
  "code": 0,
  "description": "App Snapshot Job",
  "end_time": "string",
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "message": "Complete: Successful",
  "node": {
    "name": "string"
  "start_time": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
node
name
string
The name of the node
svm
_links
_links
name
string
The name of the SVM.
uuid
string
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
