Retrieve details of an asynchronous job
Accesses the details of a specific asynchronous job, which can be useful for monitoring job progress and outcomes before it is automatically deleted.
HTTP method and endpoint
GET /cluster/jobs/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the details of a specific asynchronous job. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
uuid |
string |
path |
True |
Job UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
code |
integer |
If the state indicates "failure", this is the final error code. |
description |
string |
The description of the job to help identify it independent of the UUID. |
end_time |
string |
The time the job ended. |
error |
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed. |
message |
string |
A message corresponding to the state of the job providing additional details about the current state. |
start_time |
string |
The time the job started. |
state |
string |
The state of the job. |
svm |
uuid |
string |
"href": "/api/resourcelink"
"code": "0",
"description": "App Snapshot Job",
"end_time": "string",
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"message": "Complete: Successful",
"start_time": "string",
"state": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
