Retrieve license manager information
Accesses the license manager information to review current license configurations and status within your cluster.
HTTP method and endpoint
GET /cluster/licensing/license-managers/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves information about the license manager.
Learn more
Related ONTAP commands
system license license-manager show
uuid |
string |
path |
True |
uri.host |
string |
query |
False |
Filter by uri.host |
default |
boolean |
query |
False |
Filter by default |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
default |
boolean |
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance. |
uri |
License manager URI. |
uuid |
string |
"href": "/api/resourcelink"
"uri": {
"host": "10.1.1.1"
"uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
uri
host |
string |
License manager host name, IPv4 or IPv6 address. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
