REST API reference
Retrieve the license manager information
Accesses detailed information about the license manager, which helps you manage and monitor licensing within the system.
HTTP method and endpoint
GET /cluster/licensing/license-managers/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves information about the license manager.
  • system license license-manager show
uuid
string
path
True
default
boolean
query
False
Filter by default
uri.host
string
query
False
Filter by uri.host
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
default
boolean
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance.
uri
uri
License manager URI.
uuid
string
      "href": "/api/resourcelink"
  "uri": {
    "host": "10.1.1.1"
  "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
uri
host
string
License manager host name, IPv4 or IPv6 address.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
