REST API reference
Retrieves unix-group cache settings
learn more
  • [doc /name-services/cache/unix-group/settings](#docs-name-services-name-services_cache_unix-group_settings)
GET /name-services/cache/unix-group/settings
Introduced In: 9.11
Retrieves unix-group cache settings.
  • vserver services name-service cache unix-group settings show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
negative_ttl
string
query
False
Filter by negative_ttl
propagation_enabled
boolean
query
False
Filter by propagation_enabled
negative_cache_enabled
boolean
query
False
Filter by negative_cache_enabled
ttl
string
query
False
Filter by ttl
enabled
boolean
query
False
Filter by enabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[unix_group_settings]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "negative_ttl": "PT5M",
      "svm": {
        "name": "svm1",
      "ttl": "PT24H"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
unix_group_settings
UNIX groups cache setting.
_links
_links
enabled
boolean
Indicates whether or not the cache is enabled.
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
propagation_enabled
boolean
Specifies whether the propagation setting is enabled or not.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
