Retrieve UNIX group cache settings
Retrieves UNIX group cache settings to view the current configuration and status of cached UNIX group information within your storage environment.
HTTP method and endpoint
GET /name-services/cache/unix-group/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves unix-group cache settings.
Related ONTAP commands
vserver services name-service cache unix-group settings show
Learn more
negative_cache_enabled |
boolean |
query |
False |
Filter by negative_cache_enabled |
ttl |
string |
query |
False |
Filter by ttl |
propagation_enabled |
boolean |
query |
False |
Filter by propagation_enabled |
enabled |
boolean |
query |
False |
Filter by enabled |
negative_ttl |
string |
query |
False |
Filter by negative_ttl |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[unix_group_settings] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
unix_group_settings
UNIX groups cache setting.
_links |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
boolean |
Specifies whether the propagation setting is enabled or not. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
