Retrieve an applied restricted group policy for an SVM
Accesses the applied policy of a restricted group for a specified SVM to understand the current configuration and restrictions in place.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/restricted-groups/{policy_index}/{group_name}
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied policy of restricted group for specified SVM.
Related ONTAP commands
vserver cifs group-policy restricted-group show-applied
policy_index |
integer |
path |
True |
Group policy index. |
group_name |
string |
path |
True |
Group name. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
group_name |
string |
link |
string |
Link info. |
members |
array[string] |
Members of the group. |
memberships |
array[string] |
Group is member of Group/OU. |
policy_name |
string |
svm |
Will not be populated for objects that are yet to be applied. |
version |
integer |
Group policy object version. |
"group_name": "test_group",
"link": "domain",
"members": [
"DOMAIN/test_user",
"DOMAIN/user2"
"memberships": [
"DOMAIN/AdministratorGrp",
"DOMAIN/deptMark"
"policy_name": "test_policy",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"version": 7
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
