REST API reference
Retrieve an applied restricted group policy for an SVM
Accesses the applied policy of a restricted group for a specified SVM to understand the current configuration and restrictions in place.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/restricted-groups/{policy_index}/{group_name}
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied policy of restricted group for specified SVM.
  • vserver cifs group-policy restricted-group show-applied
policy_index
integer
path
True
Group policy index.
group_name
string
path
True
Group name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
group_name
string
link
string
Link info.
members
array[string]
Members of the group.
memberships
array[string]
Group is member of Group/OU.
policy_name
string
svm
svm
Will not be populated for objects that are yet to be applied.
version
integer
Group policy object version.
  "group_name": "test_group",
  "link": "domain",
  "members": [
    "DOMAIN/test_user",
    "DOMAIN/user2"
  "memberships": [
    "DOMAIN/AdministratorGrp",
    "DOMAIN/deptMark"
  "policy_name": "test_policy",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
