REST API reference
Retrieves a shadowcopy set
learn more
  • [doc /protocols/cifs/shadow-copies](#docs-nas-protocols_cifs_shadow-copies)
GET /protocols/cifs/shadowcopy-sets/{uuid}
Introduced In: 9.11
Retrieves a Shadowcopy set
  • vserver cifs shadowcopy show-sets
uuid
string
path
True
Storage shadowcopy set ID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
  "keep_snapshots": "",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
