Retrieve a shadow copy set
GET /protocols/cifs/shadowcopy-sets/{uuid}
Introduced In: 9.11
Retrieves a Shadowcopy set
Related ONTAP commands
vserver cifs shadowcopy show-sets
Learn more
uuid |
string |
path |
True |
Storage shadowcopy set ID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
keep_snapshots |
boolean |
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy set. |
"keep_snapshots": "",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
