REST API reference
Retrieve a CIFS share
Retrieves information about a CIFS share, helping you understand its configuration and properties.
HTTP method and endpoint
GET /protocols/cifs/shares/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a CIFS share.
  • vserver cifs share show
  • vserver cifs share properties show
name
string
path
True
Share Name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access_based_enumeration
boolean
If enabled, all folders inside this share are visible to a user based on that individual user access right; prevents the display of folders or other shared resources that the user does not have access to.
acls
array[acls]
allow_unencrypted_access
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
browsable
boolean
Specifies whether or not the Windows clients can browse the share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
continuously_available
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback.
dir_umask
integer
Directory Mode Creation Mask to be viewed as an octal number.
encryption
boolean
Specifies that SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
integer
File Mode Creation Mask to be viewed as an octal number.
force_group_for_create
string
Specifies that all files that CIFS users create in a specific share belong to the same group (also called the "force-group"). The "force-group" must be a predefined group in the UNIX group database. This setting has no effect unless the security style of the volume is UNIX or mixed security style.
home_directory
boolean
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
  • Default value: 1
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
name
string
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow a unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specify whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
path
string
The fully-qualified pathname in the owning SVM namespace that is shared through this share. If this is a home directory share then the path should be dynamic by specifying the pattern %w (Windows user name), %u (UNIX user name), or %d (domain name) variables in any combination. ONTAP generates the path dynamically for the connected user and this path is appended to each search path to find the full Home Directory path.
  • example: /volume_1/eng_vol/
  • maxLength: 256
  • minLength: 1
  • x-nullable: true
show_previous_versions
boolean
Specifies that the previous version can be viewed and restored from the client.
show_snapshot
boolean
Specifies whether or not the Snapshot copies can be viewed and traversed by clients.
svm
svm
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
volume
volume
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
      "href": "/api/resourcelink"
  "acls": [
      "permission": "string",
      "type": "string",
      "user_or_group": "ENGDOMAIN\\ad_user"
  "comment": "HR Department Share",
  "dir_umask": 18,
  "file_umask": 18,
  "force_group_for_create": "string",
  "name": "HR_SHARE",
  "offline_files": "string",
  "path": "/volume_1/eng_vol/",
  "svm": {
    "name": "svm1",
  "unix_symlink": "string",
  "volume": {
    "name": "volume1",
  "vscan_profile": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
acls
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • x-nullable: true
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
