Retrieve a CIFS share
Retrieves information about a CIFS share, helping you understand its configuration and properties.
HTTP method and endpoint
GET /protocols/cifs/shares/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a CIFS share.
Related ONTAP commands
vserver cifs share show -
vserver cifs share properties show
Learn more
name |
string |
path |
True |
Share Name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access_based_enumeration |
boolean |
If enabled, all folders inside this share are visible to a user based on that individual user access right; prevents the display of folders or other shared resources that the user does not have access to. |
acls |
array[acls] |
allow_unencrypted_access |
boolean |
Specifies whether or not the SMB2 clients are allowed to access the encrypted share. |
attribute_cache |
boolean |
Specifies that connections through this share cache attributes for a short time to improve performance. |
browsable |
boolean |
Specifies whether or not the Windows clients can browse the share. |
change_notify |
boolean |
Specifies whether CIFS clients can request for change notifications for directories on this share. |
comment |
string |
Specify the CIFS share descriptions. |
continuously_available |
boolean |
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback. If the Vscan ONTAP feature is used, it is not supported in continuous availability (CA) shares.
dir_umask |
string |
Directory Mode Creation Mask to be viewed as an octal number. |
encryption |
boolean |
Specifies that SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share. |
file_umask |
string |
File Mode Creation Mask to be viewed as an octal number. |
force_group_for_create |
string |
Specifies that all files that CIFS users create in a specific share belong to the same group (also called the "force-group"). The "force-group" must be a predefined group in the UNIX group database. This setting has no effect unless the security style of the volume is UNIX or mixed security style. |
home_directory |
boolean |
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
max_connections_per_share |
integer |
Maximum number of tree connections on share. |
name |
string |
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically. |
namespace_caching |
boolean |
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers. |
no_strict_security |
boolean |
Specifies whether or not CIFS clients can follow a unix symlinks outside the share boundaries. |
offline_files |
string |
Offline Files The supported values are:
oplocks |
boolean |
Specify whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations. |
path |
string |
The fully-qualified pathname in the owning SVM namespace that is shared through this share. If this is a home directory share then the path should be dynamic by specifying the pattern %w (Windows user name), %u (UNIX user name), or %d (domain name) variables in any combination. ONTAP generates the path dynamically for the connected user and this path is appended to each search path to find the full Home Directory path.
show_previous_versions |
boolean |
Specifies that the previous version can be viewed and restored from the client. |
show_snapshot |
boolean |
Specifies whether or not the snapshots can be viewed and traversed by clients. |
svm |
unix_symlink |
string |
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
volume |
vscan_profile |
string |
Vscan File-Operations Profile The supported values are:
"href": "/api/resourcelink"
"acls": [
"permission": "string",
"type": "string",
"user_or_group": "ENGDOMAIN\\ad_user",
"win_sid_unix_id": "string"
"comment": "HR Department Share",
"dir_umask": "21",
"file_umask": "21",
"force_group_for_create": "string",
"name": "HR_SHARE",
"offline_files": "string",
"path": "/volume_1/eng_vol/",
"svm": {
"name": "svm1",
"unix_symlink": "string",
"volume": {
"name": "volume1",
"vscan_profile": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
acls
The permissions that users and groups have on a CIFS share.
_links |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
win_sid_unix_id |
string |
Windows SID/UNIX ID depending on access-control type. |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
