Retrieve Kerberos realms
Retrieves Kerberos realms to view their configuration and manage authentication settings for your network resources.
HTTP method and endpoint
GET /protocols/nfs/kerberos/realms
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nfs kerberos realm show
Learn more
password_server.port |
integer |
query |
False |
Filter by password_server.port
password_server.address |
string |
query |
False |
Filter by password_server.address
name |
string |
query |
False |
Filter by name |
clock_skew |
integer |
query |
False |
Filter by clock_skew
comment |
string |
query |
False |
Filter by comment |
admin_server.address |
string |
query |
False |
Filter by admin_server.address
admin_server.port |
integer |
query |
False |
Filter by admin_server.port
ad_server.name |
string |
query |
False |
Filter by ad_server.name |
ad_server.address |
string |
query |
False |
Filter by ad_server.address |
encryption_types |
string |
query |
False |
Filter by encryption_types |
kdc.vendor |
string |
query |
False |
Filter by kdc.vendor |
kdc.ip |
string |
query |
False |
Filter by kdc.ip |
kdc.port |
integer |
query |
False |
Filter by kdc.port
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[kerberos_realm] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"ad_server": {
"address": "1.2.3.4",
"name": "string"
"admin_server": {
"comment": "string",
"encryption_types": [
"string"
"kdc": {
"ip": "1.2.3.4",
"port": 88,
"vendor": "string"
"name": "string",
"password_server": {
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ad_server
address |
string |
Active Directory server IP address |
name |
string |
Active Directory server name |
admin_server
address |
string |
Admin server IP address. |
port |
integer |
Specifies the port number of admin server. |
kdc
ip |
string |
KDC IP address |
port |
integer |
KDC port |
vendor |
string |
Key Distribution Center (KDC) vendor. Following values are suported:
password_server
address |
string |
Password server IP address. |
port |
integer |
Specifies the port number of password server. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
kerberos_realm
_links |
ad_server |
admin_server |
clock_skew |
integer |
Specifies the allowed time of clock-skew between the server and clients, in minutes. |
comment |
string |
Comment |
encryption_types |
array[string] |
kdc |
name |
string |
Kerberos realm |
password_server |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
