REST API reference
Retrieve Kerberos realms
Retrieves Kerberos realms to access the configuration details necessary for managing Kerberos authentication in your environment.
HTTP method and endpoint
GET /protocols/nfs/kerberos/realms
Introduced in
ONTAP 9.6
  • vserver nfs kerberos realm show
encryption_types
string
query
False
Filter by encryption_types
kdc.ip
string
query
False
Filter by kdc.ip
kdc.port
integer
query
False
Filter by kdc.port
  • Max value: 65535
  • Min value: 1
kdc.vendor
string
query
False
Filter by kdc.vendor
admin_server.address
string
query
False
Filter by admin_server.address
  • Introduced in: 9.13
admin_server.port
integer
query
False
Filter by admin_server.port
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
password_server.address
string
query
False
Filter by password_server.address
password_server.port
integer
query
False
Filter by password_server.port
comment
string
query
False
Filter by comment
name
string
query
False
Filter by name
clock_skew
integer
query
False
Filter by clock_skew
ad_server.name
string
query
False
Filter by ad_server.name
ad_server.address
string
query
False
Filter by ad_server.address
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[kerberos_realm]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ad_server": {
        "address": "1.2.3.4",
        "name": "string"
      "admin_server": {
      "comment": "string",
      "encryption_types": [
        "string"
      "kdc": {
        "ip": "1.2.3.4",
        "port": 88,
        "vendor": "string"
      "name": "string",
      "password_server": {
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ad_server
address
string
Active Directory server IP address
name
string
Active Directory server name
admin_server
address
string
Admin server IP address.
port
integer
Specifies the port number of admin server.
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are suported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
password_server
address
string
Password server IP address.
port
integer
Specifies the port number of password server.
svm
_links
_links
name
string
uuid
string
kerberos_realm
_links
_links
ad_server
ad_server
admin_server
admin_server
clock_skew
integer
Specifies the allowed time of clock-skew between the server and clients, in minutes.
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
password_server
password_server
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
