REST API reference
Retrieves kerberos realms
learn more
  • [doc /protocols/nfs/kerberos/realms](#docs-nas-protocols_nfs_kerberos_realms)
GET /protocols/nfs/kerberos/realms
Retrieves Kerberos realms.
  • vserver nfs kerberos realm show
name
string
query
False
Filter by name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
comment
string
query
False
Filter by comment
kdc.vendor
string
query
False
Filter by kdc.vendor
kdc.ip
string
query
False
Filter by kdc.ip
kdc.port
integer
query
False
Filter by kdc.port
ad_server.address
string
query
False
Filter by ad_server.address
ad_server.name
string
query
False
Filter by ad_server.name
encryption_types
string
query
False
Filter by encryption_types
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[kerberos_realm]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "ad_server": {
        "address": "1.2.3.4",
        "name": "string"
      "comment": "string",
      "encryption_types": [
        "string"
      "kdc": {
        "ip": "1.2.3.4",
        "port": 88,
        "vendor": "string"
      "name": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ad_server
address
string
Active Directory server IP address
name
string
Active Directory server name
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are suported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
svm
_links
_links
name
string
The name of the SVM.
uuid
string
kerberos_realm
_links
_links
ad_server
ad_server
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
