Retrieve an NVMe interface
Retrieves an NVMe interface to access details about the configuration and status of the interface. Use this to monitor and manage your NVMe connections effectively.
HTTP method and endpoint
GET /protocols/nvme/interfaces/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme show-interface
Learn more
uuid |
string |
path |
True |
The unique identifier of the NVMe interface. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
The administrative state of the NVMe interface. |
fc_interface |
The attributes specific to a Fibre Channel-based NVMe interface. This is populated when |
interface_type |
string |
The underlying interface type of the NVMe interface. This property identifies which of fc_interface and ip_interface will be further populated. |
ip_interface |
The attributes specific to an IP-based NVMe interface. This is populated when |
name |
string |
The name of the NVMe interface. |
node |
svm |
transport_address |
string |
The transport address of the NVMe interface. |
transport_protocols |
array[string] |
The transport protocols supported by the NVMe interface. |
uuid |
string |
"href": "/api/resourcelink"
"fc_interface": {
"port": {
"name": "0a",
"node": {
"name": "node1"
"wwnn": "20:00:00:50:56:b4:13:a9",
"wwpn": "20:00:00:50:56:b4:13:a8"
"interface_type": "string",
"ip_interface": {
"ip": {
"address": "10.10.10.7"
"location": {
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "lif1",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
"transport_protocols": [
"string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The supplied SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
fc_interface
This is populated when interface_type is fc_interface.
_links |
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
wwnn |
string |
The WWNN (world wide node name) of the Fibre Channel NVMe interface. |
wwpn |
string |
The WWPN (world wide port name) of the Fibre Channel NVMe interface. |
self_link
self |
ip
address |
string |
IPv4 or IPv6 address |
node
name |
string |
Name of node on which the port is located. |
port_reference
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
location
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
ip_interface
This is populated when interface_type is ip_interface.
_links |
ip |
location |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
