REST API reference
Retrieve an NVMe interface
Retrieves an NVMe interface to provide details on the current configuration and status of the interface.
HTTP method and endpoint
GET /protocols/nvme/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • vserver nvme show-interface
uuid
string
path
True
The unique identifier of the NVMe interface.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
The administrative state of the NVMe interface.
fc_interface
fc_interface
The attributes specific to a Fibre Channel-based NVMe interface.
This is populated when interface_type is fc_interface.
interface_type
string
The underlying interface type of the NVMe interface. This property identifies which of fc_interface and ip_interface will be further populated.
ip_interface
ip_interface
The attributes specific to an IP-based NVMe interface.
This is populated when interface_type is ip_interface.
name
string
The name of the NVMe interface.
node
node
svm
svm
transport_address
string
The transport address of the NVMe interface.
transport_protocols
array[string]
The transport protocols supported by the NVMe interface.
uuid
string
      "href": "/api/resourcelink"
  "fc_interface": {
    "port": {
      "name": "0a",
      "node": {
        "name": "node1"
    "wwnn": "20:00:00:50:56:b4:13:a9",
    "wwpn": "20:00:00:50:56:b4:13:a8"
  "interface_type": "string",
  "ip_interface": {
    "ip": {
      "address": "10.10.10.7"
    "location": {
      "port": {
        "name": "e1b",
        "node": {
          "name": "node1"
  "name": "lif1",
  "node": {
    "name": "node1",
  "svm": {
    "name": "svm1",
  "transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
  "transport_protocols": [
    "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links
_links
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
fc_interface
_links
_links
port
port
wwnn
string
The WWNN (world wide node name) of the Fibre Channel NVMe interface.
wwpn
string
The WWPN (world wide port name) of the Fibre Channel NVMe interface.
self
ip
address
string
IPv4 or IPv6 address
node
name
string
Name of node on which the port is located.
port_reference
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links
_links
name
string
node
node
uuid
string
location
port
port_reference
ip_interface
_links
self_link
ip
ip
location
location
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
