Retrieve an NVMe interface
GET /protocols/nvme/interfaces/{uuid}
Retrieves an NVMe interface.
Related ONTAP commands
vserver nvme show-interface
Learn more
fields |
array[string] |
query |
False |
uuid |
string |
path |
True |
The unique identifier of the NVMe interface. |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
The administrative state of the NVMe interface. |
fc_interface |
The attributes specific to a Fibre Channel-based NVMe interface. |
name |
string |
The name of the NVMe interface. |
node |
svm |
transport_address |
string |
The transport address of the NVMe interface. |
uuid |
string |
"href": "/api/resourcelink"
"fc_interface": {
"port": {
"name": "0a",
"node": {
"name": "node1"
"wwnn": "20:00:00:50:56:b4:13:a9",
"wwpn": "20:00:00:50:56:b4:13:a8"
"name": "lif1",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The supplied SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
fc_interface
_links |
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
wwnn |
string |
The WWNN (world wide node name) of the Fibre Channel NVMe interface. |
wwpn |
string |
The WWPN (world wide port name) of the Fibre Channel NVMe interface. |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
