REST API reference
Retrieves an initiator of an initiator group
expensive properties
there is an added computational cost to retrieving values for these properties they are not included by default in get results and must be explicitly requested using the fields query parameter see [requesting specific fields](requesting_specific_fields) to learn more * connectivity_tracking* related ontap commands * lun igroup show # learn more * [doc /protocols/san/igroups](#docs-san-protocols_san_igroups)
GET /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced In: 9.6
Retrieves an initiator of an initiator group. This API only reports initiators owned directly by the initiator group. Initiators of nested initiator groups are not part of this collection.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity_tracking.*
  • lun igroup show
igroup.uuid
string
path
True
The unique identifier of the initiator group.
name
string
path
True
Initiator name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
Overview of the initiator's connections to ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
igroup
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
      "href": "/api/resourcelink"
  "comment": "string",
  "connectivity_tracking": {
    "alerts": [
        "summary": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
    "connection_state": "string",
    "connections": [
        "logins": [
            "interface": {
              "fc": {
                "name": "fc_lif1",
                "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                "wwpn": "20:00:00:50:56:b4:13:a8"
              "ip": {
                "ip": {
                  "address": "10.10.10.7"
                "name": "lif1",
            "last_seen_time": "2021-03-14 05:19:00 +0000"
        "node": {
          "name": "node1",
  "igroup": {
    "name": "igroup1",
  "name": "iqn.1998-01.com.corp.iscsi:name1"
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The initiator is not a member of the initiator group.
5374852
The initiator group specified in the URI does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
alerts
summary
summary
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interface
fc
fc
An FC interface.
ip
ip
logins
connected
boolean
True if the initiator is currently logged in to this connection's interface.
interface
interface
last_seen_time
string
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported.
node
_links
_links
name
string
uuid
string
connections
logins
array[logins]
node
node
alerts
array[alerts]
connection_state
string
Connection state.
connections
array[connections]
igroup
_links
_links
name
string
The name of the initiator group.
uuid
string
records
_links
_links
comment
string
name
string
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
