Retrieve an initiator
Retrieves an initiator of an initiator group to access detailed information about its configuration. This information can be useful when managing or troubleshooting connections within your storage network.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced in
ONTAP 9.6
Usage notes
This API only reports initiators owned directly by the initiator group. Initiators of nested initiator groups are not part of this collection.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
connectivity_tracking.*
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
name |
string |
path |
True |
The initiator name. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
connectivity_tracking |
Overview of the initiator's connections to ONTAP.
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
proximity |
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET. These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The |
"href": "/api/resourcelink"
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"connection_state": "string",
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"last_seen_time": "2021-03-14 05:19:00 +0000"
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1",
"proximity": {
"peer_svms": [
"name": "peer1",
"uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The initiator is not a member of the initiator group. |
5374852 |
The initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
alerts
summary |
A user friendly message describing the connection state. |
fc
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
ip
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interface
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
logins
connected |
boolean |
True if the initiator is currently logged in to this connection's interface. |
interface |
last_seen_time |
string |
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported. |
node
_links |
name |
string |
uuid |
string |
connections
logins |
array[logins] |
node |
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
connections |
array[connections] |
igroup
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
peer_svms
A reference to an SVM peer relationship.
_links |
name |
string |
The local name of the peer SVM. This name is unique among all local and peer SVMs. |
uuid |
string |
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself. |
proximity
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm |
boolean |
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the |
peer_svms |
array[peer_svms] |
An array of remote peer SVMs to which the initiator is proximal. |
records
_links |
comment |
string |
name |
string |
proximity |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
