REST API reference
Retrieve portSet network interfaces
Retrieves the interfaces associated with a portset, helping you understand the network configuration and connectivity within your storage environment.
HTTP method and endpoint
GET /protocols/san/portsets/{portset.uuid}/interfaces
Introduced in
ONTAP 9.9
Usage notes
Retrieves interfaces of a portset.
  • lun portset show
portset.uuid
string
path
True
The unique identifier of the portset.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[portset_interface]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "fc": {
        "name": "fc_lif1",
        "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "ip": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
      "portset": {
Status: Default
ONTAP Error Response Codes
Error Code Description
5374908
The portset specified in the URI does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
portset
The portset in which the network interface is found.
Note that this does not mean that the network interface cannot also be found in other portsets.
_links
_links
uuid
string
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links
_links
fc
fc
An FC interface.
ip
ip
uuid
string
The unique identifier of the network interface.
portset_interface
_links
_links
fc
fc
An FC interface.
ip
ip
portset
portset
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
