Retrieve portset network interfaces
Retrieves network interfaces associated with a portset. Use this to examine the configuration of interfaces within the portset.
HTTP method and endpoint
GET /protocols/san/portsets/{portset.uuid}/interfaces
Introduced in
ONTAP 9.9
Usage notes
Retrieves interfaces of a portset.
Related ONTAP commands
lun portset show
Learn more
portset.uuid |
string |
path |
True |
The unique identifier of the portset. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[portset_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"portset": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374908 |
The portset specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
fc
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
ip
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
portset
The portset in which the network interface is found.
Note that this does not mean that the network interface cannot also be found in other portsets.
_links |
uuid |
string |
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links |
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
uuid |
string |
The unique identifier of the network interface. |
portset_interface
_links |
fc |
An FC interface. |
ip |
portset |
The portset in which the network interface is found. Note that this does not mean that the network interface cannot also be found in other portsets. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
