REST API reference
Retrieve portsets
Retrieves portsets to access their current configurations and status within the ONTAP environment. This operation is useful when you need to review or manage portset details for SAN protocol operations.
HTTP method and endpoint
GET /protocols/san/portsets
Introduced in
ONTAP 9.9
  • lun portset show
igroups.name
string
query
False
Filter by igroups.name
  • maxLength: 96
  • minLength: 1
igroups.uuid
string
query
False
Filter by igroups.uuid
protocol
string
query
False
Filter by protocol
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
interfaces.ip.ip.address
string
query
False
Filter by interfaces.ip.ip.address
interfaces.ip.name
string
query
False
Filter by interfaces.ip.name
interfaces.ip.uuid
string
query
False
Filter by interfaces.ip.uuid
interfaces.uuid
string
query
False
Filter by interfaces.uuid
interfaces.fc.name
string
query
False
Filter by interfaces.fc.name
interfaces.fc.uuid
string
query
False
Filter by interfaces.fc.uuid
interfaces.fc.wwpn
string
query
False
Filter by interfaces.fc.wwpn
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
  • maxLength: 96
  • minLength: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[portset]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "igroups": [
          "name": "igroup1",
      "interfaces": [
          "fc": {
            "name": "fc_lif1",
            "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
            "wwpn": "20:00:00:50:56:b4:13:a8"
          "ip": {
            "ip": {
              "address": "10.10.10.7"
            "name": "lif1",
      "name": "portset1",
      "protocol": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interfaces
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
_links
_links
fc
fc
An FC interface.
ip
ip
uuid
string
The unique identifier of the network interface.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
portset
_links
_links
igroups
array[igroups]
An array initiator groups to which the portset is bound.
interfaces
array[interfaces]
An array of network interfaces that are members of the portset. These are the only network interfaces through which the initiators of a bound igroup can access mapped LUNs.
Zero or more network interfaces can be supplied when the portset is created. After creation, network interfaces can be added or removed from the portset using the /protocols/san/portsets/{portset.uuid}/interfaces endpoint. See POST /protocols/san/portsets/{portset.uuid}/interfaces and DELETE /protocols/san/portsets/{portset.uuid}/interfaces/{uuid} for more details.
name
string
The name of the portset. Required in POST.
The name of a portset cannot be changed after creation.
protocol
string
The protocols supported by the portset. This restricts the type of network interfaces that can be added to the portset. Optional in POST; if not supplied, this defaults to mixed.
The protocol of a portset cannot be changed after creation.
svm
svm
uuid
string
The unique identifier for a portset.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
