Retrieves a specific resource for a specific tag
GET /resource-tags/{resource_tag.value}/resources/{href}
Introduced In: 9.13
Retrieves a specific resource for a specific tag.
resource_tag.value |
string |
path |
True |
href |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
label |
string |
This is a human-readable classifier representing the type of thing that is pointed to by the href. |
svm |
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned. |
"label": "volume",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
