REST API reference
Retrieve a resource for a tag
Retrieves a specific resource associated with a particular tag, helping you manage and organize tagged resources effectively.
HTTP method and endpoint
GET /resource-tags/{resource_tag.value}/resources/{href}
Introduced in
ONTAP 9.13
Usage notes
Retrieves a specific resource for a specific tag.
resource_tag.value
string
path
True
  • format: key:value
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
string
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties.
label
string
This is a human-readable classifier representing the type of thing that is pointed to by the href.
svm
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
value
string
The text value of the tag formatted as key:value.
  "href": "string",
  "label": "volume",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "value": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
