REST API reference
Retrieve key manager configurations
Retrieves key manager configurations, providing details on how your system manages encryption keys across nodes.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
Introduced in
ONTAP 9.11
Required properties
  • security_key_manager.uuid - Key manager UUID.
  • node.uuid - Node UUID.
  • security key-manager key query
key_tag
string
query
False
Filter by key_tag
  • Introduced in: 9.12
encryption_algorithm
string
query
False
Filter by encryption_algorithm
key_user
string
query
False
Filter by key_user
key_manager
string
query
False
Filter by key_manager
key_server
string
query
False
Filter by key_server
policy
string
query
False
Filter by policy
crn
string
query
False
Filter by crn
key_type
string
query
False
Filter by key_type
key_store_type
string
query
False
Filter by key_store_type
node.name
string
query
False
Filter by node.name
key_id
string
query
False
Filter by key_id
restored
boolean
query
False
Filter by restored
key_store
string
query
False
Filter by key_store
string
path
True
Key manager UUID.
node.uuid
string
path
True
Node UUID.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[key_manager_keys]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "crn": "CRN=v1:bluemix:public:containers-kubernetes",
      "encryption_algorithm": "XTS-AES-256",
      "key_id": "000000000000000002000000000001008963c9213194c59555c1bec8db3603c800000000",
      "key_manager": "keyserver1.local:5696",
      "key_server": "keyserver1.com:5698",
      "key_store": "string",
      "key_store_type": "string",
      "key_tag": "key#",
      "key_type": "string",
      "key_user": "vs1",
      "node": {
        "name": "node1",
      "policy": "IBM_Key_Lore",
      "restored": 1
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
node
_links
_links
name
string
uuid
string
key_manager_keys
Displays the keys stored in a key manager.
_links
self_link
crn
string
Cloud resource name.
string
Encryption algorithm for the key
key_id
string
Key identifier.
key_manager
string
Key manager key server managing the key. Indicates the external key server when external key manager is configured.
key_server
string
External key server for key management.
key_store
string
Security key manager configured for the given key manager UUID. Key manager keystore value can be onboard or external.
key_store_type
string
Security key manager keystore type. Keystore type can be onboard, external, or supported cloud key manager.
key_tag
string
Additional information associated with the key.
key_type
string
Encryption Key type.
key_user
string
SVM associated with the key.
node
node
policy
string
Key store policy.
restored
boolean
Indicates whether the key is present locally on the node.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
