Retrieve key manager configurations
Retrieves key manager configurations to view current security settings and manage encryption effectively within your environment.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
Introduced in
ONTAP 9.11
Required properties
security_key_manager.uuid- Key manager UUID. -
node.uuid- Node UUID.
Related ONTAP commands
security key-manager key query -
security key-manager key query -node <node> -
security key-manager key query -node <node> -key-manager <key_manager>
key_type |
string |
query |
False |
Filter by key_type
scope |
string |
query |
False |
Filter by scope
key_user |
string |
query |
False |
Filter by key_user
key_tag |
string |
query |
False |
Filter by key_tag
key_store |
string |
query |
False |
Filter by key_store
crn |
string |
query |
False |
Filter by crn
key_server |
string |
query |
False |
Filter by key_server
key_id |
string |
query |
False |
Filter by key_id
key_store_type |
string |
query |
False |
Filter by key_store_type
restored |
boolean |
query |
False |
Filter by restored
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
encryption_algorithm |
string |
query |
False |
Filter by encryption_algorithm
node.name |
string |
query |
False |
Filter by node.name
key_manager |
string |
query |
False |
Filter by key_manager
policy |
string |
query |
False |
Filter by policy
security_key_manager.uuid |
string |
path |
True |
Key manager UUID. |
node.uuid |
string |
path |
True |
Node UUID. |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_manager_keys] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"crn": "CRN=v1:bluemix:public:containers-kubernetes",
"encryption_algorithm": "XTS-AES-256",
"key_id": "000000000000000002000000000001008963c9213194c59555c1bec8db3603c800000000",
"key_manager": "keyserver1.local:5696",
"key_server": "keyserver1.com:5698",
"key_store": "string",
"key_store_type": "string",
"key_tag": "key#",
"key_type": "string",
"key_user": "vs1",
"node": {
"name": "node1",
"policy": "IBM_Key_Lore",
"restored": 1,
"scope": "string",
"security_key_manager": {
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537125 |
The provided key manager UUID is not the UUID of a keymanager. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
Security key manager object reference.
_links |
uuid |
string |
Key manager UUID |
svm
_links |
name |
string |
uuid |
string |
key_manager_keys
Displays the keys stored in a key manager.
_links |
crn |
string |
Cloud resource name. |
string |
Encryption algorithm for the key |
key_id |
string |
Key identifier. |
key_manager |
string |
Key manager key server managing the key. Indicates the external key server when external key manager is configured. |
key_server |
string |
External key server for key management. |
key_store |
string |
Security key manager configured for the given key manager UUID. Key manager keystore value can be onboard or external. |
key_store_type |
string |
Security key manager keystore type. Keystore type can be onboard, external, or supported cloud key manager. |
key_tag |
string |
Additional information associated with the key. |
key_type |
string |
Encryption Key type. |
key_user |
string |
SVM associated with the key. |
node |
policy |
string |
Key store policy. |
restored |
boolean |
Indicates whether the key is present locally on the node. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
security_key_manager |
Security key manager object reference. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
