REST API reference
Retrieve multi-admin-verify approval groups
Retrieves multi-admin-verify approval groups to access the list of groups that require multiple administrative approvals. This helps ensure that changes to the system are securely managed and authorized by the appropriate personnel.
HTTP method and endpoint
GET /security/multi-admin-verify/approval-groups
Introduced in
ONTAP 9.11
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
email
string
query
False
Filter by email
approvers
string
query
False
Filter by approvers
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[multi_admin_verify_approval_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "approvers": [
        "string"
      "email": [
        "string"
      "name": "string",
      "owner": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
The owner of the approval group. The only valid owner is currently the cluster.
_links
_links
name
string
The name of the SVM.
uuid
string
approvers
array[string]
List of users that can approve a request.
email
array[string]
Email addresses that are notified when a request is created, approved, vetoed, or executed.
name
string
Name of the approval group.
owner
owner
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
