Retrieve multi-admin-verify approval groups
Retrieves multi-admin-verify approval groups to review the current approval group configurations. This helps you manage and verify administrative actions that require multiple approvals.
HTTP method and endpoint
GET /security/multi-admin-verify/approval-groups
Introduced in
ONTAP 9.11
string |
query |
False |
Filter by email |
approvers |
string |
query |
False |
Filter by approvers |
owner.name |
string |
query |
False |
Filter by owner.name |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"approvers": [
"string"
"email": [
"string"
"name": "string",
"owner": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
The owner of the approval group. The only valid owner is currently the cluster.
_links |
name |
string |
The name of the SVM. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
multi_admin_verify_approval_group
approvers |
array[string] |
List of users that can approve a request. |
array[string] |
Email addresses that are notified when a request is created, approved, vetoed, or executed. |
name |
string |
Name of the approval group. |
owner |
The owner of the approval group. The only valid owner is currently the cluster. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
