Check the status of an active file move operation
Checks the status of an ongoing file move operation to monitor its progress and ensure successful completion.
HTTP method and endpoint
GET /storage/file/moves/{node.uuid}/{uuid}/{index}
Introduced in
ONTAP 9.12
Overview
Retrieve the status of an on-going file move operation.
Related ONTAP commands
volume file move show -
volume rebalance file-move show
node.uuid |
string |
path |
True |
Unique identifier of the node. |
uuid |
string |
path |
True |
Unique identifier of the file move operation. |
index |
integer |
path |
True |
The index of the file move within the overall operation |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
cutover_time |
integer |
Time that the file move operation takes before cutover completes, in seconds. |
destination |
Destination file information. |
elapsed_time |
integer |
Time elapsed since the start of the file move operation, in seconds. |
failure |
Contains the most recent failure reason for move operation. |
index |
integer |
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct. |
is_destination_ready |
boolean |
Indicates whether the destination file is ready for use. |
is_flexgroup |
boolean |
Indicates whether this is a FlexGroup file move operation. |
is_snapshot_fenced |
boolean |
Indicates whether Snapshot copies are fenced. |
max_cutover_time |
integer |
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations. |
max_throughput |
integer |
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer. |
node |
Node hosting the destination of this move operation. |
scanner |
source |
Source file information. |
svm |
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation. |
uuid |
string |
The UUID which uniquely identifies the job that started this move operation. |
volume |
"cutover_time": 8,
"destination": {
"path": "d1/d2/file1",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"volume": {
"name": "volume1",
"elapsed_time": 100,
"failure": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"index": 0,
"max_cutover_time": 10,
"max_throughput": 250000,
"node": {
"name": "node1",
"scanner": {
"percent": 80,
"progress": 80000,
"state": "string",
"total": 100000
"source": {
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
"uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
destination
path |
string |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
destinations
path |
string |
svm |
volume |
sources
path |
string |
svm |
volume |
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
destinations |
array[destinations] |
The destination file information. |
sources |
array[sources] |
The source file information. |
node
_links |
name |
string |
uuid |
string |
svm
SVM of the source reference file.
_links |
name |
string |
uuid |
string |
volume
Volume of the source reference file.
_links |
name |
string |
uuid |
string |
reference
Reference file information.
scanner
percent |
integer |
Scanner progress, as a percentage. |
progress |
integer |
Scanner progress, in bytes scanned. |
state |
string |
Status of the file move scanner. |
total |
integer |
Total bytes to be scanned. |
source
path |
string |
svm |
volume |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
