REST API reference
Check the status of an active file move operation
Checks the status of an active file move operation to monitor its progress and ensure successful completion.
HTTP method and endpoint
GET /storage/file/moves/{node.uuid}/{uuid}/{index}
Introduced in
ONTAP 9.12
Overview
Retrieve the status of an on-going file move operation.
  • volume file move show
  • volume rebalance file-move show
node.uuid
string
path
True
Unique identifier of the node.
uuid
string
path
True
Unique identifier of the file move operation.
index
integer
path
True
The index of the file move within the overall operation
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
cutover_time
integer
Time that the file move operation takes before cutover completes, in seconds.
destination
destination
Destination file information.
elapsed_time
integer
Time elapsed since the start of the file move operation, in seconds.
failure
error
Contains the most recent failure reason for move operation.
index
integer
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct.
is_destination_ready
boolean
Indicates whether the destination file is ready for use.
is_flexgroup
boolean
Indicates whether this is a FlexGroup file move operation.
is_snapshot_fenced
boolean
Indicates whether snapshots are fenced.
max_cutover_time
integer
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations.
max_throughput
integer
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer.
node
node
Node hosting the destination of this move operation.
scanner
scanner
source
source
Source file information.
svm
svm
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation.
uuid
string
The UUID which uniquely identifies the job that started this move operation.
volume
volume
  "cutover_time": 8,
  "destination": {
    "path": "d1/d2/file1",
    "svm": {
          "href": "/api/resourcelink"
      "name": "svm1",
    "volume": {
      "name": "volume1",
  "elapsed_time": 100,
  "failure": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "index": 0,
  "max_cutover_time": 10,
  "max_throughput": 250000,
  "node": {
    "name": "node1",
  "scanner": {
    "percent": 80,
    "progress": 80000,
    "state": "string",
    "total": 100000
  "source": {
    "svm": {
      "name": "svm1",
    "volume": {
      "name": "volume1",
  "svm": {
    "name": "svm1",
  "uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
6521
Cannot quiesce source file. Source file "file.name" is under construction and is being used by either a file copy or move operation. Wait a few minutes and try the operation again.
6522
Volume is not VM aligned.
6523
File suffix not VM aligned.
6524
Completion interface not specified.
6525
Maximum simultaneous file operations reached.
6526
Lock conflict.
6527
Permission denied.
6528
Waiting for an I/O fence to be released.
6529
Waiting for space to become available.
6530
Waiting for an external process to complete.
6531
Source volume was deleted.
6532
Slowed due to resource constraints.
6533
Volume does not support block reallocation.
6534
File operation not supported.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
destination
path
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
destinations
Path for file move operation.
path
string
svm
svm
volume
volume
sources
path
string
svm
svm
volume
volume
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
destinations
array[destinations]
The destination file information.
sources
array[sources]
The source file information.
node
_links
_links
name
string
uuid
string
svm
SVM of the source reference file.
_links
_links
name
string
uuid
string
volume
Volume of the source reference file.
_links
_links
name
string
uuid
string
  • x-nullable: true
reference
Reference file information.
scanner
percent
integer
Scanner progress, as a percentage.
progress
integer
Scanner progress, in bytes scanned.
state
string
Status of the file move scanner.
total
integer
Total bytes to be scanned.
source
path
string
svm
svm
volume
volume
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
uuid
string
  • x-nullable: true
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
