Retrieve storage switches
Retrieves a collection of storage switches to view details about the network devices connected to your storage environment.
HTTP method and endpoint
GET /storage/switches
Introduced in
ONTAP 9.9
Related ONTAP commands
storage switch show
Learn more
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[storage_switch] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"connections": [
"peer_port": {
"connection": "string",
"type": "string",
"unique_id": "string",
"wwn": "string"
"source_port": {
"mode": "string",
"name": "string",
"wwn": "string"
"errors": [
"component": {
"name": "string"
"reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"severity": "string",
"type": "string"
"fabric_name": "string",
"fans": [
"name": "string",
"state": "string"
"firmware_version": "string",
"ip_address": "string",
"model": "string",
"monitored_blades": [
"integer"
"name": "string",
"paths": [
"adapter": {
"name": "string",
"type": "string",
"wwn": "string"
"node": {
"name": "node1",
"port": {
"name": "string"
"ports": [
"mode": "string",
"name": "string",
"sfp": {
"serial_number": "string",
"transmitter_type": "string",
"type": "string"
"state": "string",
"wwn": "string"
"power_supply_units": [
"name": "string",
"state": "string"
"role": "string",
"state": "string",
"symbolic_name": "string",
"temperature_sensors": [
"name": "string",
"state": "string"
"vendor": "string",
"vsans": [
"load_balancing_types": "string",
"name": "string",
"state": "string"
"wwn": "string",
"zones": [
"name": "string",
"port": {
"id": "string",
"name": "string"
"wwn": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
peer_port
connection |
string |
Storage switch peer port host and name |
type |
string |
Storage switch peer type |
unique_id |
string |
Storage switch peer unique ID |
wwn |
string |
Storage switch peer port world wide name |
source_port
mode |
string |
Storage switch port operating mode |
name |
string |
Storage switch port name |
wwn |
string |
connections
peer_port |
source_port |
component
id |
integer |
Error component ID |
name |
string |
Error component name |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
errors
component |
reason |
severity |
string |
Error component severity |
type |
string |
Error component type |
fans
name |
string |
Storage switch fan name |
speed |
integer |
Storage switch fan speed |
state |
string |
Storage switch fan state |
adapter
name |
string |
Node adapter name |
type |
string |
Node adapter type |
wwn |
string |
Node adapter world wide name |
_links
self |
node
_links |
name |
string |
uuid |
string |
port
name |
string |
speed |
integer |
Storage switch port speed, in Gbps |
paths
adapter |
node |
port |
sfp
serial_number |
string |
Storage switch port SFP serial number |
transmitter_type |
string |
Storage switch port SFP transmitter type |
type |
string |
Storage switch port SFP type |
ports
enabled |
boolean |
Indicates whether the storage switch port is enabled. |
mode |
string |
Storage switch port mode |
name |
string |
sfp |
speed |
integer |
state |
string |
Storage switch port state |
wwn |
string |
Storage switch port world wide name |
power_supply_units
name |
string |
Power supply unit name |
state |
string |
Power supply unit state |
temperature_sensors
name |
string |
Temperature sensor name |
reading |
integer |
Temperature sensor reading, in degrees celsius. |
state |
string |
Temperature sensor state |
vsans
id |
integer |
Storage switch VSAN ID |
iod |
boolean |
Indicates whether in-order delivery is set for a zone. |
load_balancing_types |
string |
Storage switch VSAN load balancing type |
name |
string |
Storage switch VSAN name |
state |
string |
Storage switch VSAN Port state |
port
id |
string |
Storage switch zone port ID |
name |
string |
Storage switch zone port |
zones
id |
integer |
Storage switch zone ID |
name |
string |
Storage switch zone name |
port |
wwn |
string |
Storage switch zone world wide name |
storage_switch
The Storage switch object describes the storage switch properties, features and cabling.
connections |
array[connections] |
director_class |
boolean |
domain_id |
integer |
Domain ID |
errors |
array[errors] |
fabric_name |
string |
Storage switch fabric name |
fans |
array[fans] |
firmware_version |
string |
Storage switch firmware version |
ip_address |
string |
IP Address |
local |
boolean |
Indicates whether the storage switch is directly connected to the reporting cluster. |
model |
string |
Storage switch model. |
monitored_blades |
array[integer] |
Indicates the blades that are being monitored for a director-class switch. |
monitoring_enabled |
boolean |
Indicates whether monitoring is enabled for the storage switch. |
name |
string |
Storage switch name |
paths |
array[paths] |
ports |
array[ports] |
power_supply_units |
array[power_supply_units] |
role |
string |
Storage switch role in fabric. |
state |
string |
Storage switch state |
symbolic_name |
string |
Storage switch symbolic name |
temperature_sensors |
array[temperature_sensors] |
vendor |
string |
Storage switch vendor |
vsans |
array[vsans] |
wwn |
string |
Storage switch world wide name |
zones |
array[zones] |
