REST API reference
Retrieve storage switches
Retrieves a collection of storage switches to view details about the network devices connected to your storage environment.
HTTP method and endpoint
GET /storage/switches
Introduced in
ONTAP 9.9
  • storage switch show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[storage_switch]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "connections": [
          "peer_port": {
            "connection": "string",
            "type": "string",
            "unique_id": "string",
            "wwn": "string"
          "source_port": {
            "mode": "string",
            "name": "string",
            "wwn": "string"
      "errors": [
          "component": {
            "name": "string"
          "reason": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
            "message": "entry doesn't exist"
          "severity": "string",
          "type": "string"
      "fabric_name": "string",
      "fans": [
          "name": "string",
          "state": "string"
      "firmware_version": "string",
      "ip_address": "string",
      "model": "string",
      "monitored_blades": [
        "integer"
      "name": "string",
      "paths": [
          "adapter": {
            "name": "string",
            "type": "string",
            "wwn": "string"
          "node": {
            "name": "node1",
          "port": {
            "name": "string"
      "ports": [
          "mode": "string",
          "name": "string",
          "sfp": {
            "serial_number": "string",
            "transmitter_type": "string",
            "type": "string"
          "state": "string",
          "wwn": "string"
      "power_supply_units": [
          "name": "string",
          "state": "string"
      "role": "string",
      "state": "string",
      "symbolic_name": "string",
      "temperature_sensors": [
          "name": "string",
          "state": "string"
      "vendor": "string",
      "vsans": [
          "load_balancing_types": "string",
          "name": "string",
          "state": "string"
      "wwn": "string",
      "zones": [
          "name": "string",
          "port": {
            "id": "string",
            "name": "string"
          "wwn": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
peer_port
connection
string
Storage switch peer port host and name
type
string
Storage switch peer type
unique_id
string
Storage switch peer unique ID
wwn
string
Storage switch peer port world wide name
source_port
mode
string
Storage switch port operating mode
name
string
Storage switch port name
wwn
string
connections
peer_port
peer_port
source_port
source_port
component
id
integer
Error component ID
name
string
Error component name
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
errors
component
component
reason
error
severity
string
Error component severity
type
string
Error component type
fans
name
string
Storage switch fan name
speed
integer
Storage switch fan speed
state
string
Storage switch fan state
adapter
name
string
Node adapter name
type
string
Node adapter type
wwn
string
Node adapter world wide name
self
node
_links
_links
name
string
uuid
string
port
name
string
speed
integer
Storage switch port speed, in Gbps
paths
adapter
adapter
node
node
port
port
sfp
serial_number
string
Storage switch port SFP serial number
transmitter_type
string
Storage switch port SFP transmitter type
type
string
Storage switch port SFP type
ports
enabled
boolean
Indicates whether the storage switch port is enabled.
mode
string
Storage switch port mode
name
string
sfp
sfp
speed
integer
state
string
Storage switch port state
wwn
string
Storage switch port world wide name
power_supply_units
name
string
Power supply unit name
state
string
Power supply unit state
temperature_sensors
name
string
Temperature sensor name
reading
integer
Temperature sensor reading, in degrees celsius.
state
string
Temperature sensor state
vsans
id
integer
Storage switch VSAN ID
iod
boolean
Indicates whether in-order delivery is set for a zone.
string
Storage switch VSAN load balancing type
name
string
Storage switch VSAN name
state
string
Storage switch VSAN Port state
port
id
string
Storage switch zone port ID
name
string
zones
id
integer
Storage switch zone ID
name
string
Storage switch zone name
port
port
wwn
string
Storage switch zone world wide name
storage_switch
The Storage switch object describes the storage switch properties, features and cabling.
connections
array[connections]
director_class
boolean
domain_id
integer
Domain ID
errors
array[errors]
fabric_name
string
Storage switch fabric name
fans
array[fans]
firmware_version
string
Storage switch firmware version
ip_address
string
IP Address
local
boolean
Indicates whether the storage switch is directly connected to the reporting cluster.
model
string
Storage switch model.
monitored_blades
array[integer]
Indicates the blades that are being monitored for a director-class switch.
monitoring_enabled
boolean
Indicates whether monitoring is enabled for the storage switch.
name
string
Storage switch name
paths
array[paths]
ports
array[ports]
power_supply_units
array[power_supply_units]
role
string
Storage switch role in fabric.
state
string
Storage switch state
symbolic_name
string
Storage switch symbolic name
temperature_sensors
array[temperature_sensors]
vendor
string
Storage switch vendor
vsans
array[vsans]
wwn
string
Storage switch world wide name
zones
array[zones]
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
