REST API reference
Retrieve volume Snapshot copy details
Retrieves detailed information about a specific volume Snapshot copy. This is useful when you need to inspect the Snapshot's configuration or status.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves details of a specific volume Snapshot copy.
  • snapshot show
volume.uuid
string
path
True
Volume UUID
uuid
string
path
True
Snapshot copy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.
create_time
string
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.
delta
snapshot_delta
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a Snapshot copy and the Active File System, only the Snapshot copy name needs to be mentioned.
expiry_time
string
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
logical_size
integer
Size of the logical used file system at the time the Snapshot copy is captured.
name
string
Snapshot copy. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
Space reclaimed when the Snapshot copy is deleted, in bytes.
size
integer
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value.
snaplock_expiry_time
string
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes.
snapmirror_label
string
Label for SnapMirror operations
state
string
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.
svm
svm
uuid
string
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
      "href": "/api/resourcelink"
  "comment": "string",
  "create_time": "2019-02-04 19:00:00 +0000",
  "delta": {
    "size_consumed": 0,
    "time_elapsed": "string"
  "expiry_time": "2019-02-04 19:00:00 +0000",
  "logical_size": 1228800,
  "name": "this_snapshot",
  "owners": [
    "string"
  "provenance_volume": {
    "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
  "size": "122880",
  "snaplock_expiry_time": "2019-02-04 19:00:00 +0000",
  "snapmirror_label": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response Code
Error Code Description
2
An invalid value was entered for one of the fields.
262197
An invalid field was specified in the request.
1638473
Snapshot copy tag not found.
1638503
The Snapshot copy does not exist on the specified volume.
1638600
The Snapshot copy does not exist.
1638615
Bulk operations for Snapshot copies are not supported on multiple SVMs.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
snapshot_delta
_links
_links
size_consumed
integer
Indicates the space that has changed between two specified WAFL file systems, in bytes.
time_elapsed
string
Time elapsed between two specified WAFL file systems.
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
