Retrieve volume Snapshot copy details
Retrieves details of a specific volume Snapshot copy to examine its properties and status within your storage system.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot show
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
uuid |
string |
path |
True |
Snapshot copy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH. |
create_time |
string |
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created. |
expiry_time |
string |
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached. |
name |
string |
Snapshot copy. Valid in POST or PATCH. |
owners |
array[string] |
size |
integer |
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value. |
snaplock_expiry_time |
string |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. |
snapmirror_label |
string |
Label for SnapMirror operations |
state |
string |
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid. |
svm |
uuid |
string |
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume. |
volume |
"href": "/api/resourcelink"
"comment": "string",
"create_time": "2019-02-04T19:00:00Z",
"expiry_time": "2019-02-04T19:00:00Z",
"name": "this_snapshot",
"owners": [
"string"
"size": "122880",
"snaplock_expiry_time": "2019-02-04T19:00:00Z",
"snapmirror_label": "string",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
