Retrieve core dumps
Retrieves a collection of core dumps to review diagnostic information and troubleshoot system issues effectively.
HTTP method and endpoint
GET /support/coredump/coredumps
Introduced in
ONTAP 9.10
Usage notes
Retrieves a collection of coredumps.
Related ONTAP commands
system node coredump show
is_saved |
boolean |
query |
False |
Filter by is_saved |
panic_time |
string |
query |
False |
Filter by panic_time |
md5_data_checksum |
string |
query |
False |
Filter by md5_data_checksum |
name |
string |
query |
False |
Filter by name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
size |
integer |
query |
False |
Filter by size |
type |
string |
query |
False |
Filter by type |
is_partial |
boolean |
query |
False |
Filter by is_partial |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[coredump] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"md5_data_checksum": "5118488cc5065e33a16986001b1ffa48",
"name": "core.4136886413.2021-03-01.22_09_11.nz",
"node": {
"name": "node1",
"panic_time": "2021-03-01 22:09:11 +0000",
"size": 1161629804,
"type": "kernel"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
coredump
_links |
is_partial |
boolean |
Specifies whether or not the core is a partial core. Applicable only to kernel core dump type. |
is_saved |
boolean |
Specifies whether or not the core file is saved. |
md5_data_checksum |
string |
MD5 checksum of the compressed data of core. Applicable only to kernel core dump type. |
name |
string |
Core name |
node |
panic_time |
string |
Time of panic that generated the core. |
size |
integer |
Size of core, in bytes. Applicable only to kernel core dump type. |
type |
string |
Core type, kernel or application |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
