REST API reference
Retrieve core dumps
Retrieves core dumps to examine system crash data and diagnose issues within your ONTAP environment.
HTTP method and endpoint
GET /support/coredump/coredumps
Introduced in
ONTAP 9.10
Usage notes
Retrieves a collection of coredumps.
  • system node coredump show
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
is_partial
boolean
query
False
Filter by is_partial
panic_time
string
query
False
Filter by panic_time
is_saved
boolean
query
False
Filter by is_saved
md5_data_checksum
string
query
False
Filter by md5_data_checksum
name
string
query
False
Filter by name
type
string
query
False
Filter by type
size
integer
query
False
Filter by size
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[coredump]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "md5_data_checksum": "5118488cc5065e33a16986001b1ffa48",
      "name": "core.4136886413.2021-03-01.22_09_11.nz",
      "node": {
        "name": "node1",
      "panic_time": "2021-03-01 18:09:11 -0400",
      "size": 1161629804,
      "type": "kernel"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
coredump
_links
_links
is_partial
boolean
Specifies whether or not the core is a partial core. Applicable only to kernel core dump type.
is_saved
boolean
Specifies whether or not the core file is saved.
md5_data_checksum
string
MD5 checksum of the compressed data of core. Applicable only to kernel core dump type.
name
string
Core name
node
node
panic_time
string
Time of panic that generated the core.
size
integer
Size of core, in bytes. Applicable only to kernel core dump type.
type
string
Core type, kernel or application
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
