Manage cluster-wide SNMP configuration
Configure and manage SNMP settings across your cluster using these endpoints. Adjust parameters such as SNMP protocol status, authentication traps, and SNMP traps to optimize network monitoring. Additionally, trigger SNMP test traps to verify configurations.
Overview
Cluster wide SNMP configuration. You can configure or retrieve the following SNMP parameters using this endpoint:
enable or disable SNMP
enable or disable SNMP authentication traps
enable or disable SNMP traps
## This endpoint can also be used to trigger an SNMP test trap.
Disables SNMP protocol in the cluster.
# The API:
PATCH "/api/support/snmp"
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"false"}'
# The response
200 OK
Enables SNMP authentication traps in the cluster.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"auth_traps_enabled":"true"}'
# The response
200 OK
Enables SNMP protocol and SNMP authentication traps in the cluster.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"true", "auth_traps_enabled":"true"}'
# The response
200 OK
Disables the SNMP trap subsystem in the cluster. Once the SNMP trap subsystem is disabled, the cluster stops sending SNMP traps.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"traps_enabled":"false"}'
# The response
200 OK
Triggers an SNMP test trap.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"trigger_test_trap":"true"}'
#The response
200 OK
Enables the SNMP protocol in the cluster, SNMP traps, and triggers an SNMP test trap.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"true", "traps_enabled":"true", "trigger_test_trap":"true"}'
# The response
200 OK
