Manage cluster-wide SNMP configuration
Configure and manage cluster-wide SNMP settings, including enabling or disabling SNMP protocol, authentication traps, and SNMP traps. Use these endpoints to tailor SNMP behavior and initiate test traps for monitoring purposes.
Overview
Cluster wide SNMP configuration. You can configure or retrieve the following SNMP parameters using this endpoint:
enable or disable SNMP
enable or disable SNMP authentication traps
enable or disable SNMP traps
## This endpoint can also be used to trigger an SNMP test trap.
Disables SNMP protocol in the cluster.
# The API:
PATCH "/api/support/snmp"
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"false"}'
# The response
200 OK
Enables SNMP authentication traps in the cluster.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"auth_traps_enabled":"true"}'
# The response
200 OK
Enables SNMP protocol and SNMP authentication traps in the cluster.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"true", "auth_traps_enabled":"true"}'
# The response
200 OK
Disables the SNMP trap subsystem in the cluster. Once the SNMP trap subsystem is disabled, the cluster stops sending SNMP traps.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"traps_enabled":"false"}'
# The response
200 OK
Sets the contact and location for the SNMP server
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"contact":"support@company.com", "location":"Building 1"}'
#The response
200 OK
Triggers an SNMP test trap.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"trigger_test_trap":"true"}'
#The response
200 OK
Enables the SNMP protocol in the cluster, SNMP traps, and triggers an SNMP test trap.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"true", "traps_enabled":"true", "trigger_test_trap":"true"}'
# The response
200 OK
