Manage environment sensors
Access and monitor platform environment sensors to obtain real-time data on node conditions and performance metrics. Use this information to ensure optimal operation and identify potential issues within your ONTAP cluster environment.
Overview
You can use this API to retrieve the details of all platform environment sensors
Retrieving values of a single sensor
# The API:
GET /api/cluster/sensors/{node.uuid}/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/sensors/{node.uuid}/{index}" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"node": {
"uuid": "19ec0b4a-4a4d-11ec-9036-d039ea4a991a",
"name": "node1",
"href": "/api/cluster/nodes/19ec0b4a-4a4d-11ec-9036-d039ea4a991a"
"index": 1,
"name": "PVCCSA CPU FD",
"type": "voltage",
"value": 831,
"value_units": "mV",
"threshold_state": "normal",
"critical_low_threshold": 297,
"warning_low_threshold": 396,
"warning_high_threshold": 1485,
"critical_high_threshold": 1683,
"href": "/api/cluster/sensors/19ec0b4a-4a4d-11ec-9036-d039ea4a991a/1"
